Thread Tools Search this Thread share on Facebook
  #1
Old 05-18-2009, 05:29 PM
watchdude1's Avatar
watchdude1 watchdude1 is offline
Last classified ad: 350 chevy engine heads...
327 engine ticking
HI I have a chevy 327 engine with hydraulic lifters the one lifter is making a ticking noise I started the engine adjusted the lifter until the ticking stops then locked the nut let run 5 miniutes and it starts ticking again, I put another nut untop of the locking nut ,maybe it was not holding but it still start ticking . I think it maybe the stud is coming out? it is the same height as the other ones I put a straight edge from one to the other they are the same height, could it be a bad valve?
what can i do to stop this ticking it is only one valve the exhaust valve.
Put screw studs in ?
Register now (free) or login to remove ads
Old 05-18-2009, 06:25 PM
Crazy Mopar Guy's Avatar
Crazy Mopar Guy Crazy Mopar Guy is offline
You could pin the stud if you want, or swap to screw in studs.
I've seen screw in studs with poly locks back off because the top of the screw in studs weren't machined flat.
Try setting the valves and see if the stud is pulling, measure each time the ticking returns. Is there any way one lifter is bleeding down? Excessive lifter bore clearance or..?
Old 05-18-2009, 06:37 PM
oldbogie oldbogie is offline
More likely, it's a bad valve inside the lifter that's letting it leak down under valve spring load. A test would be to stop the engine with that valve open and see what it sounds like in the morning. Setting like that with the valve open will keep a load on it overnight, if the internal lifter check valve is leaking it should be quite noisy on start-up.
Bogie
Old 05-18-2009, 06:42 PM
poncho62's Avatar
poncho62 poncho62 is offline
Last journal entry: 51 Ford F1
Wiki Edits: 5
Have you checked the rocker arm?....it may be cracked and getting worse each time you set the valves. If not that have a look at the number of threads showing....If there are more showing on that one, the lifter is collapsing.
In the words of Walter Cronkite..."And that's the way it is."
Ontario Rodders
Old 05-19-2009, 09:39 AM
aaronious1 aaronious1 is offline
i just had that same problem on a 350. one lifter and one cam lobe was shot. i'm flushing the engine and going with a new cam and lifter set. comp instead of elgin, hopefully that helps.......
Old 05-22-2009, 07:14 PM
watchdude1's Avatar
I am thinking of putting a new cam and lifters in my 327 what is a good setup for me what type of cam is a reliable one comp,crane what lift is good,one that has a nice lopey sound but stil idles . and how much trouble is it to install would I need to remove the intake manifold or can I get the lifters out through the push rod hole
I can buy a stroker 383 for 2k would that be cheaper to do less work.?
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "327 engine ticking"
ThreadThread StarterForumRepliesLast Post
Port or Full time vacuumcool rockin daddyEngine12910-05-2010 03:00 PM
1985 C-6 truck tranny, no engine braking effectfast68Transmission - Rearend4002-04-2008 05:55 PM
327 truck engine ???richallEngine501-04-2008 12:18 PM
Cam Helpblack66Engine305-12-2003 06:15 PM
sick 327 engine67burbEngine110-16-2002 02:50 PM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
