327 Flywheel - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-15-2006, 11:00 AM
327 Flywheel
I got a 327 that im putting in my camaro with a 700 r4.i have a flywheel that bolted to a L98 350 motor will this flywheel work or do i have to get a different one?Thanks,Steve
Old 08-15-2006, 02:18 PM
DoubleVision's Avatar
nope it won`t work. the balance is different and so is the bolt pattern. you`ll need a older 2 piece seal 168 tooth flexplate. but make sure and check your block to see if it`ll accept a staggerd bolt pattern starter. a flexplate from any pre 1986 small block will work. Keep in mind there were 2 patterns for 2 different flexplate/starter combo`s, the straight pattern starter only works on a 153 tooth flexplate, the staggerd works with the 168.
Old 08-15-2006, 03:09 PM
ok,the block has three bolt holes for a starter,so i can get a pre 86 flywheel for it and that would work with the three bolt starter right?
Old 08-17-2006, 08:30 PM
small block starters only have 2 holes.
they can however have a straight across pattern or a diagonal or staggered pattern with different length bolts.
Old 08-17-2006, 08:52 PM
well the 327 that i have has three of them in the block all threaded and they do make a three bolt starter.now dont get me wrong i never knew that a sbc had a three bolt starter all i ever dealt with was two bolt straighht and diagonal like you mentioned.
Old 08-17-2006, 10:28 PM
if there is a 3 bolt small block starter then a picture would be worth a thousand words.
just because I haven't had the oportunity to see one doesn't mean they don't exist so anything new learned is welcome information.
Old 08-17-2006, 10:35 PM
MI2600's Avatar
Member# 3287
The really rare ones have four bolts.
Old 08-18-2006, 12:12 AM
ok ive never seen a 4 bolt starter or even heard of one are you serious????now its been a while since i built a chevy ive been building fords for years so maybe my minds playing tricks on me or whatever but am i correct in saying that most small block chevys have only two mounting holes for the starter.the reason why im questioning this is i took a straight bolt pattern starter and was able to use it on the 327 it came off a l98 350 motor and i used the two holes closest to the back of the block and i am going to use a flywheel for a 84 camaro with the o/d trans im just hoping it all will work together.as far as the three bolt starter i called auto zone and had them pull up a starter from a 67 chevelle with a 327 and he verified it was a three bolt starter.i just want to make sure that this is going to all work together properly,thats all.
Chevrolet 327 TEEMCDEE9552 Engine 15 06-09-2007 09:22 PM
Removing flywheel to converter bolts in a 1958 Chevy Impala 348 Cast Iron Powerglide 1958imp348 Transmission - Rearend 9 11-22-2004 04:18 PM
327 flexplate / flywheel bolts backing out bigmacou Engine 5 09-07-2004 07:38 PM
Flywheel Inertia BillyShope Suspension - Brakes - Steering 3 09-02-2004 07:44 PM
Flywheel balancing? nomis30 Engine 3 11-26-2003 12:03 AM
