327 help
i have a 67 chevy 327 in a 85 chevy c10 and i need to wire up a ignition coil resistor... this truck came with hei so i have to wire the resistor all by hand and i need to know how to wire it up to the truck which is for hei. how do i wire up the resistor? ive never had to do this so all and any help is appreciated
May I ask why your going back with a points ignition system? Why not stick with the HEI?
Mike |
Use the HEI and forget the resistor. That is 45 year old technology. Why would you want to limit your spark and use points in a newer vehicle? HEI runs better and is much more reliable, stick with it.
Well I put a hei distributor in it and I wasn't getting fire and everything was new on it and I know I was getting power to it but no fire... So I went back to the old style which I knew I was getting fire to begin with
Did you make sire the HEI was getting a full 12V?
Very important for it to get the full 12V.... |
Yup I also had it on a battery charger/volt tester and it said 14.4 volts and all you need is 12 so I have no idea what's wrong and that's why I went to the old style
327 help
If the distributor is a Pro Comp (or other EBay junk) you may as well buy a new one, they have lots of problems with them. |
327 help
Here is a ballast resistor from Summit Racing. Summit Racing® Ballast Resistors SUM-G5218 - SummitRacing.com If you have the original wiring harness in your truck from 1967 you will have to run a new ignition wire to the left terminal of the ballast resisstor. The wire on the right side terminal connects to the + side of the coil.
Not sure but it sounds like you are saying to ground the wire from the neg (-) side of the coil? If so that won't work at all, that wire is supposed to go to the distributor and the points. There should be three wires going to the coil, on the positive side there will be a wire from the output side of the resistor and another one from the "I" on the solenoid then on the negative terminal the wire runs to the distributor but no wire will be directly grounded anywhere. Perhaps I misunderstood what you were saying? |
| 327 hp help | lorad | Engine | 20 | 08-21-2011 01:58 PM |
| 327 need advice, opinions from guys who know their 327's | jafroyd | Engine | 9 | 07-21-2009 06:19 AM |
| 327 | luxloco | Engine | 2 | 01-20-2008 11:02 PM |
| 327 | luxloco | Engine | 3 | 01-20-2008 08:03 PM |
| Help me ID this 327 | Overdriv | Engine | 5 | 07-14-2005 09:06 PM |
