Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 327 Help & Recommendations
  #23 (permalink)
Old 05-18-2012, 06:16 AM
ap72 ap72 is offline
Banned
Originally Posted by SoCa06Z
I decided to go with the Vortec top end kit which includes modified vortecs to allow for .525 lift, E-brock RPM intake, and supporting hardware.
My question now is which cam? I have gotten mixed reviews on single pattern vs dual pattern for this setup.
Comp Recommended the following...
12-246-3
1800-6000
XE274H
274
286
230
236
.490
.490
110
My other thought was maybe the..
Lunati 227/233 at .050, .489/.504 on the lift, and it is cut on a 110 LSA
I hope you didn't order these heads already, nor the cam. Stock vortec heads will not give you enough compression, the chambers need to be cut down and they're a thin head to begin with.
If money is tight id go with a set of the 210cc 56cc chambered procomp heads. And then get a solid cam with face oiling lifters, or at least grooved lifter bores.
Thin casting vortec heads are good if you can pick up a complete used set for $100, but they are NOT a performance head. The small port bowtie vortecs would work well but they're not cheap.
