Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 327 Help & Recommendations
  #27 (permalink)
Old 05-18-2012, 10:11 AM
ap72 ap72 is offline
Banned
I assumed flat top pistons in his 327, which it likely has. The 210 runners are a little big but the'll work fine, those heads are the cheapest ones I know of to get him the compression he needs with 4vr flat top pistons.
The bowtie vortecs would be better than the procomp heads if they were milled to get you the compression you need. They're also a lot more expensive
