327 initial timing?
My Model A hot rod has a 327 SBC.
-10.1 compression -aluminum heads -300HP Chevy cam -600 cfm carb -195 themostat(never gets above 205) -I use 93 octane fuel -Delco plugs@.55 gap -MSD 6A box -Blaster coil -MSD distributor, no vac can, comes with 21 degrees advance stop bushing from MSD -new Pioneer balancer, verified TDC, timing marks With the 21 degree bushing and two light blue springs I can put 18 - 20 degrees initial timing in it without any pinging. (19 inches of vacuum). I'm looking for economy over performance (10 gallon fuel tank). My cruising RPM's are around 2650. Is that too much initial timing? Should I be changing the advance stop bushig to a 25 degree and then cut back on the initial? My fuel mileage is about 16.5 mpg. |
Every engine combination is different and in my opinion, the optimum spark lead can only be determined by experimentation and verification. If the motor is not kicking back against the starter with that much initial, then who is to say it's too much?
I think I would closely document the mileage (you said ABOUT 16.5) with the combo you have now to establish a baseline, then change it and see what happens. |
Excellent response Erik.
I would not be concerned about the 18-20 degrees initial advance, this will
improve idle quality. I agree with ericnova72 on the vacuum advance, some benefit can be found with a inefficient chamber by additional advance at light throttle. The thing to focus on is A/F ratio of all carburetor circuits. If you are serious about fuel economy consider a wide band O2 sensor. Cruse AFR should be in the 15:1 range. I have been helping with a 4000 LB Ford Lightning pick-up , dual purpose street strip. The truck recently averaged 20 MPG on the high way during the Hot Rod power tour and high 13 second performance at the local track, he is running FI. |
I think 10
I think it would be a dog with 18. I think 10 and give the distibutor 24. For fuel I would run all in at 2,500 but performance 3,000. The vacume would help.
| initial timing ? | Mr. Wormy | Engine | 6 | 05-13-2007 06:07 PM |
| Ok Sorry Another Timing Question | funbiz99 | Engine | 13 | 04-23-2007 10:14 PM |
| vacuum advance help | batman09 | Engine | 14 | 09-09-2004 09:42 PM |
| Retarding initial timing. ( try this again ) | KeithB123 | Engine | 17 | 12-09-2003 04:35 PM |
| IGNITION and CAM TIMING | sum87mustang | Engine | 3 | 07-11-2003 07:52 PM |
