327 large and small journal motors - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-07-2008, 11:00 PM
Last journal entry: The Mystery Rear End
Gentlemen
I was reading over several different posts on 327 small / large journal questions and started to get dizzy from all of the different responses. The only thing I got out of all of it is the only difference between a 327 and a 350 is the pistons and the crank. My questions are:
If I am going to utilize a 4 bolt main 350 chevy block, I assume I will need to use a large journal 327 crank and 327 pistons to turn it into a 327 motor? With 5.7 inch rods correct?
Also, I have a small journal 327 crank. I assume I would need a small journaled 307 or 327 block, with the 327 pistons and my forged small journal 327 crank to complete a small journal 327 motor (obviously with the 5.7 rods)?
Finally, do any of you know of any automotive source (on line or any hard copy document) that gives all of the different combinations that are possible to build small journal 327's and a large journal 327's?
I apologize for my ignorance on this. I haven't built a motor in more than 15 years so I've lost touch with all of the different combinations for the 327 motor (both large and small journal) and want to re-educate myself. Thanks in advance for your response.
Old 09-07-2008, 11:06 PM
yevgenievich's Avatar
Last journal entry: pictures, try#2
as far as i know 327 is a 350 with a crank out of a 283. large journal block can be made into a 327 using proper crank. Small journal block requires small journal crank but everything else should be the same
Old 09-07-2008, 11:32 PM
JeffB's Avatar
327 build
You would be better served to go the large journal route because of one issue:RODS! you can find all kinds of options for large journals and almost nil for small journal also the rod bolts are larger and stronger.
Old 09-07-2008, 11:59 PM
MI2600's Avatar
Member# 3287
Both engines used 5.7" rods. The crank journals are different sizes of course,
The small 327 engine rods are getting harder to find and weren't noted for their exceptional strength. The plus is the cranks were all forged.
The large engine rods are the same as 350 rods. You can make a large 327 with a 327 or 307 cast crank, 350 rods, and 327 pistons, all in a 350 block.
Old 09-08-2008, 03:30 AM
3rdmember
nope,you'll need a large journal 307 or 327 crank.
283 crank in a 350 will make a 302 with no oil pressure
Old 09-08-2008, 06:39 AM
chevrolet327's Avatar
second place is the first losr
Last journal entry: old stlyle holley polished valve cover
you can use small journall crank in large journal block but you need to use bearing spacer
Old 09-08-2008, 09:34 AM
lg1969's Avatar
Google "Tunnel Ram 406"
You can use large journal 307 connecting rods. They are same connecting rods used on a 350.
Old 09-08-2008, 10:01 AM
the 307 rod dont fit small journal crank
Old 09-08-2008, 11:31 AM
automotive breath's Avatar
I would get the main bearing spacers and put the SJ crank in the LJ block,
you might find someone that makes thick main beraings eleminating the need
for spacers. Scat sells good SJ rods, much stronger than stock. Then you
will need 327 pistons to make it all work.
Old 09-08-2008, 12:09 PM
lg1969's Avatar
your right about the 307 rods, But you can use a large journal 350 block which are more available then small journal block. Then use a large journal 307 crank and rods and all you need are 327 piston. Bore it out 30 overbore and will get 331cid motor using .030 327 piston.
large to small journal enginejr Engine 7 01-17-2008 08:56 PM
Small Journal or Large Journal Crank ???? S10 Racer Engine 3 12-12-2007 12:44 PM
large or small journal 327 adam15425 Engine 10 10-21-2004 06:47 AM
large journal vs small hotrod66_57 Engine 24 08-30-2004 08:36 PM
large or small jounrnal 327 Ed ke6bnl Engine 7 04-21-2003 04:21 PM
