327 oil filler tube removal - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-26-2012, 08:54 PM
69Bowtie's Avatar
I've got a 327 out of a 65 Chevelle that has a tall oil filler tube that I'd like to get rid of. I've got a PCV valve on the back side of the motor and both valve covers have vent caps. The motor has been built and is equipped with a high volume oil pump. First, how do I remove the tube and secondly will I encounter any motor issues if I plug the hole?
Old 01-26-2012, 09:26 PM
327NUT's Avatar
The tubes are usually just pressed in, with a little "elbow grease" they can be extracted and plugged off with the proper size expansion/freeze plug. Take care not to allow any debris from falling into hole when removing tube. As long as you have a good working pcv system no harm will come.
Filler tube relocation problem hp246 Hotrodding Basics 1 04-15-2010 09:02 AM
Powerglide filler tube? SECTION25 Transmission - Rearend 1 11-19-2008 09:11 AM
moving the gas filler tube mickey1031 Body - Exterior 1 08-04-2006 09:06 PM
283 Oil Filler Tube DTL504 Engine 5 11-09-2003 06:57 PM
Filler tube leak Deadtemple Transmission - Rearend 2 10-08-2003 07:39 AM
