Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 327 power questions
Old 09-01-2012, 01:24 PM
cdminter59 cdminter59 is offline
327 power questions
Now with a over-drive transmission you'll need the operating range of the cam to be in the cruise rpm. 55 mph-1500-1600 rpm/ cam op range 1300-5500 rpms. If your cams low op range is higher than your cruise rpm your engine will lug when in over-drive. I hope I am explaining this right.
