Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 327 power questions
Old 09-01-2012, 04:29 PM
vinniekq2's Avatar
vinniekq2 vinniekq2 is offline
If you want a true 375 hp then use a solid lifter flat tappet or better, advertised duration will be close to 300 with .500 lift, intake centre line and lobe displacement angle tbd. for a truck,the RPM air gap is good enough and use a 750 carb,1,5/8 headers.
