327 question - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-30-2008, 03:02 PM
327 question
Hey
I have a 67' camaro that has a 66' 327 engine, bored .30 over, 10:1 compression ratio flat top pistons, double hump heads w/ 3 angle valve job, dual z-28 valve springs, lunati cam (don't know specs right now), eldelbrock intake w/ a 650 holley carb. My question is that I would like to get maybe 400hp out of it, so what could I add (keeping the same cylinder heads) to achieve that much HP? would a matching cam and intake work ?
thanks,
Joe
Old 05-30-2008, 03:54 PM
You will need head porting and some machining for bigger valves and springs. A roller cam will also help.
A better intake and carb will also be need to reach your 400hp goal.
http://www.chevyhiperformance.com/te...ine/index.html
Old 05-30-2008, 04:00 PM
here is another one
http://www.chevyhiperformance.com/te...mer/index.html
Old 05-30-2008, 04:03 PM
last one
http://www.chevyhiperformance.com/te...ion/index.html
Old 06-02-2008, 09:45 AM
thanks
thanks for your help 454
Question about 327 67camarokid Engine 6 12-08-2005 10:40 PM
65 Impala 327 Question EazyDuzIt102 Engine 3 02-27-2004 04:30 PM
sbc 327 vs 350 Harmonic Balancer Question Ted's37 Engine 3 07-14-2003 04:10 PM
327 compression question str8_57 Engine 4 06-30-2003 11:32 PM
327 question (no, not, "is it better than...) deleteall Engine 5 03-10-2003 05:44 PM
