327 questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-26-2006, 09:12 PM
327 questions
I have some engine issues regarding the 327 in my model A hot rod. I have 11.5 inches of vacuum at 800 RPM. Does this seem to low? I also am getting oil on the spark plugs, three changes or cleanings in the first 2800 miles. There is no visible smoke from the exhaust after starting, idling or hard acceleration. The engine starts great and has no over heating problems. I have checked twice for vacuum leaks and found none. The short block was machined and assembled by a reliable builder, I did the rest at home. Any thoughts or ideas would be appreciated, its winter here now, lots of time to work on car.
327 bored 0.40
performer heads, 170-70
performer intake
600 performer carb
MSD distributor, 17 initial 37 total, all in at 3000 RPM
camshaft, 214-224 duration, .442/.465 lift, 112 lobe separation
Old 12-26-2006, 10:36 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
sounds like too much throttle opening and not enough initial timing. I can't really recommend more than that without knowing how much mechanical timing your dizzy adds.
You can play around with it at idle. Check the timing so you can return to where you were, but advance it about 4 degrees and drop the idle back down to where it was and recheck your vacuum. If it has increased you need to spend some more time tuning
Old 12-27-2006, 08:08 AM
Distributor info
The distributor is a MSD small diameter, I'm using the 20 degrees it came with from MSD. It's a pro billet model, there is no vac canister.
Old 12-27-2006, 09:04 AM
King of my Man-cave.
What kind of work was done to the heads?
tom
Old 12-27-2006, 11:12 AM
curtis73's Avatar
Wiki Edits: 16
In that case, confirm that you are at 18* initial and reset your idle.
Old 12-27-2006, 11:24 AM
re: 327 questions
With all the oil on your plugs it sounds like your rings didn't seat properly. That can happen if you ran one of those high tech synthetic oils burning your initial break-in. If they're really bad it could also cause the low vacuum. Another possible cause can be improper valve lash or cam timing.
Good luck
Old 12-27-2006, 08:49 PM
The cylinder heads were new, adjusted valve lash twice no problems, broke engine in with Q State 10-30, have run 15-40 Rotella diesel oil since break in. I hope to do a cylinder leakdown test in the next couple days. I have to make the tool first. The cam was installed straight up. I appreaciate everyones opinions, there is alot of knowledge on this board.
Old 12-27-2006, 09:35 PM
This may or may not be your problem, but new heads doesn't necessarily mean problem-free heads. Last week I replaced guides in a set of new aftermarket heads 'cause they were WAY loose. Having said that, if the second compression rings were installed upside-down, that could show good compression and leak-down results but still push oil into the cylinders.
tom
Old 12-28-2006, 12:24 AM
How does your intake manifold fit? If the manifold/heads/block were machined on the wrong angle it may not be sealing the 'valley' area and sucking oil up into the ports from below. I once saw a manual choke holley without a cable close at high speed and suck in the gasket on heavily ported heads.
Old 12-28-2006, 09:10 AM
re: 327 questions
If you're looking for a leak-down tester, I noticed that Harbor Frieght Tools has one now. It's part number 94190-0VGA for $60.00
Chevrolet 327 TEEMCDEE9552 Engine 15 06-09-2007 08:22 PM
help make my 327 angry!!! 70chevelle327 Engine 40 04-24-2007 05:33 PM
ok i got a 327 as u know i have a few questions please. Eric327 Engine 6 06-25-2005 09:32 PM
sbc 327 vs 350 Harmonic Balancer Question Ted's37 Engine 3 07-14-2003 04:10 PM
327 TO 350 CONVERSION 34FordPickUp Engine 4 08-27-2002 05:56 PM
