327 questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-05-2007, 05:15 AM
67ssguy's Avatar
327 Timing/Plug gap questions
I have a 327, bored 30, flat top pistons, 204/214 cam, 300 horse double hump heads, HEI ignition and holley 600.. What should the plug gap be, 35 and how hot of plug, any suggestions on type and number - have been using autolite 145? What should the total timing be? thanks
Old 11-05-2007, 07:04 AM
Depends on your ignition source.
1. If still points with the original coil: .035"
2. If HEI: probably about .045"-.055"
With those heads, I would think you should shoot for 36-38 degrees, total advance.
I'm sure other, more informed people will elaborate.
JA
Chevrolet 327 TEEMCDEE9552 Engine 15 06-09-2007 08:22 PM
327 build up using 1964 and earlier parts ONLY chopperimpala Engine 23 10-06-2005 01:07 PM
Differences between a 307, 327, 350? Smoked Rubber Engine 9 12-08-2004 05:15 AM
Questions, questions, questions? slider in wa Transmission - Rearend 2 09-27-2003 02:01 PM
Q Jet on a 327, question by newcomer 66nova guy Engine 7 09-15-2003 09:58 AM
