Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 327 rotating assembly
Old 04-07-2012, 07:31 PM
richard stewart 3rd's Avatar
richard stewart 3rd richard stewart 3rd is offline
Last journal entry: 351W rebuild
Hi
Welcome to Hotrodders.com Glad to have you with us.
If it's a large journal 327, you could use a 350 crank. or you could get a 383 stroker Assembly from scat or eagle & have a 383 check out power house & see what they have. Then check for a set of after market heads. And you'll need to do some clearance work. Rods to the oil pan rails, rods to the cam, rods to the bottom of the bore.
Gook luck
Rich
