Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 327 sbc build 68 nova
  #29 (permalink)
Old 02-03-2013, 07:53 PM
vinniekq2's Avatar
vinniekq2 vinniekq2 is online now
cam swap
Originally Posted by nova68 View Post
The cam I ordered is not alot smaller no, but the lobe seperation is 112 vs my old cams 106. So I know that will have a pretty big effect on getting going. Should move the powerband down also correct? Yes i understand I will give up peak power for a flat power band. I know the cam powerbands are based on a 350, which according to comp cam is 1800-6200 for the l79 plus. So I figured 2000ish for the 327? That why I said 2400 converter? Correct me If i am wrong. It is still not to late to cancel my order.
the wider lobe center moves the power up,not down.you will likely see no difference
