Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 327 Small Block Chevy that dies when I drive it
Old 02-26-2009, 02:58 PM
lg1969's Avatar
lg1969 lg1969 is offline
Google "Tunnel Ram 406"
Keith, I worked on old cars like yours. I did repair on electrical problem. One common problem I always notice is the connector behind the fuse panel. There is one main feed that goes to the fuse panel through a connector. After years of usage the connector start to overheat and start to loose contact. It start to oxidize from the heat. Before you realize, you will have intermittent connection. The car just dies and one minute later it's alive.
My 69 chevelle did that.
