I was going through the same problem in a 1967 El Camino of ours. Didn't happen all the time but every so often it would just shut off. I finally traced the problem to a corrosion problem on the wire that feeds the back of the fuse block. The solderless connector was loose as well as rusty. I cleaned the connector and soldered it this time and the problem was solved.
