327 smc - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 04-26-2010, 10:49 PM
goldenbullet44's Avatar
User that registered
Did they ever stick big blocks in buses?
  #32 (permalink)
Old 04-26-2010, 11:48 PM
ericnova72's Avatar
More for Less Racer
Yes, 366 Tall Deck and 427 Tall Deck.
Avoid the 366, its small bore and lack of room to overbore to even a 396 piston makes it a loser. Use it for the steel crank, rods, and 4-bolt main caps for a bigger BBC only. The 427 Tall Deck is a good place to start for a big stroker engine build. 4-bolt main caps and steel crank in these also.
  #33 (permalink)
Old 04-28-2010, 01:16 AM
It is kinda sickning when a guy wants to build a 327 or other engine and many of the following post try and persuade the the person to build a 350.
If you are going to buy one of the dinosaur boat anchor 350 Vortecs whey would't you buy a 5.3 or 6.0 instead when they are so cheap and plentiful and you can make 400-500 hp with very little modification.
  #34 (permalink)
Old 04-28-2010, 06:35 AM
Banned
number one reason is cost. a 450Vortec enigne in your car will end up costing you less than 3 grand, to put a 550 6.0L in an older car requires fab work and with headers, mounts, adapters etc you can be in for about 6 grand.
  #35 (permalink)
Old 05-01-2010, 12:32 AM
327 build.
Nothing wrong with a 327. If it is a small journal, better aftermarket rods can be had at a reasonable cost on Ebay. Stock rods need better 11/32 bolts (Think ARP) but they are very good quality forgings. All pre-68 327's were small journal cranks and all SJ 327 cranks were forged steel, not cast. They are actually the heaviest crank Chevy made for a gen 1 SBC,. very stout. Flat top hyperutectic pistons are availible for the 327. Comp cams solid flat tappet 268 or 270 cam, good set of 64 cc heads and you will have a street screamer. Hey, dare to be different! Thats what hotrodding is all about.
sbc identification numbers ? 68 Chevy C-10 Engine 23 01-19-2010 12:02 PM
327 large and small journal motors 31 Ford Coupe Engine 9 09-08-2008 12:09 PM
327 '89 Trans Am GTA suggestions 3rdGenFreak Engine 2 06-29-2007 07:45 PM
Chevrolet 327 TEEMCDEE9552 Engine 15 06-09-2007 08:22 PM
SMC repairs with Duramix sevt_chevelle Body - Exterior 4 09-17-2004 06:29 PM
