Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 327 spark plug issues
  #82 (permalink)
Old 09-05-2012, 12:37 PM
cdminter59 cdminter59 is offline
Originally Posted by 70nova327 View Post
now that you mention that no its not, it was at first but when the engine started acting up it was cranking over really slow and struggling, it doesnt normally do that at all.
This is what it does when the initial timing is too far advanced. Tonight when you check the timing be sure to always unplug the vacuum line to the distributor. It will probably be advanced off the scale. If it is set it back to 10-12*. That and the mechanical the distributor adds will give you 35-36* total.
