Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 327 spark plug issues
  #84 (permalink)
Old 09-05-2012, 01:27 PM
cdminter59 cdminter59 is offline
Originally Posted by 70nova327 View Post
ok, remember when i had it at TDC when i checked it with the dowel it read that TDC was at 8* BTDC, should i take that 8* into consideration? like if its showing at 8* consider that at 0*?
No, The dowel was stopping the piston 1/2 from TDC. Just start it up, disconnect vacuum line to the distributor and plug, hook up the timing light and shine it at the scale. Check where the balancer line is. Loosen distributor and set to 10-12*. Tighten distributor clamp. If something else is happening it is not timing related. BTW you never gave me an answer on how old is this motor. How many miles on it?
