327 spark plug issues
IDK. Hook up the timing light to see where you are at. Does this engine have a performance camshaft? You may have too much initial and mechanical advance that 's why you need to check the initial timing with the light. You may have to used ported vacuum ( the left side port). Too much to speculation without knowing the timing curve.
when i first got the car it ran with the vacuum cone on the dist pointing at say 8 'oclock standing at the front of the car but recently the only way it runs well is at 4'oclock, but when i disconnected that vacuum line last night it ran at 8 again. not sure if that tells you anything.
The position of the vacuum advance can doesn't mean anything. Just set it up so it won't hit anything when adjusting the distributor timing. Have you looked at the timing with the light yet? Get it where it runs the best. I hope it will be at about 12-16* BTDC.
i will tonight, after it popped gas back up thru the carb i couldnt get it started again, it does this and then in the morning it fires right up. i think this is what you were referring to about the fuel getting to hot. is that vapor lock?
Vapor lock is when the fuel in the lines in the engine compartment get to hot (can hear it boil) or the fuel in the carburetor get too hot. You won't get fuel to the squirtters in the carburetor. The popping is a lean condition. Is the starter motor turning fast and free?
now that you mention that no its not, it was at first but when the engine started acting up it was cranking over really slow and struggling, it doesnt normally do that at all.
This is what it does when the initial timing is too far advanced. Tonight when you check the timing be sure to always unplug the vacuum line to the distributor. It will probably be advanced off the scale. If it is set it back to 10-12*. That and the mechanical the distributor adds will give you 35-36* total.
ok, remember when i had it at TDC when i checked it with the dowel it read that TDC was at 8* BTDC, should i take that 8* into consideration? like if its showing at 8* consider that at 0*?
No, The dowel was stopping the piston 1/2 from TDC. Just start it up, disconnect vacuum line to the distributor and plug, hook up the timing light and shine it at the scale. Check where the balancer line is. Loosen distributor and set to 10-12*. Tighten distributor clamp. If something else is happening it is not timing related. BTW you never gave me an answer on how old is this motor. How many miles on it?
i have no clue how old it is or the milage, the kid i bought it from didnt know much about it and only had for 6 months, i do know that its been converted from the 250 6 cyl and the column shift to the 327 and 350 trans, along with all new suspension and the disc brake conversion, so it seems at one point somebody loved it and put some time and money in it.
so plug off the canister and the carb as well when timing?
and what affect would my fuel pump have had on it when it was pushing 8.5 PSI out?
No just plug the end of the vacuum hose that you take off the distributor can. The can does not pull vacuum. Edelbrock carburetors recommend 5-5.5 lbs. of fuel pressure. Eventually it will blow the needle and seat inside the carburetor and damage the float. Maybe that's why your plugs were wet with gas. Carb leaking down after you turn it off.
Here is the Edelbrock carburetor manual. It has tuning for your carb too. http://www.edelbrock.com/automotive_...404_manual.pdf
| 89 5.0 H.O. spark plug wireing/spark order | psikpa | Modern Electronic Engines | 6 | 05-11-2012 08:01 PM |
| Spark plug for 416 haeds on 327 | Dougie | Hotrodding Basics | 4 | 04-21-2012 05:42 PM |
| Chevy 327 - recommend spark plug wires | KENMO | Electrical | 7 | 07-22-2011 05:26 AM |
| spark plug gap 327 hei | helrazr3 | Hotrodding Basics | 3 | 06-26-2011 09:08 PM |
| Spark plug wires jumping spark | STATUTORY GRAPE | Engine | 4 | 10-04-2009 05:14 AM |
