327 starter - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-10-2013, 09:06 PM
327 starter
I haveve just dropped in my engine and transmission. 327 small block and TH350. i have everything hooked up right i just have a question about the starter... when i go to turn the key the starter to me sounds like its hitting the flexplate and grinding the teeth... should i buy a new aftermarket starter or put shims on the starter?
Old 02-11-2013, 04:15 AM
DoubleVision's Avatar
Was you running this combo previously or have you just now pieced it together? I ask since there are 2 starters that operate off 2 flexplate sizes.
The small 12 inch 153 tooth flexplate uses a starter with a pattern that's straight across. The large 14 inch 168 tooth flexplate uses a starter with a staggerd pattern. If these are used mismatched it can cause a problem as you've discribed. I'll also ask is the starter tightened good? Were the correct shouldered bolts with a knurled section used? Also make sure there are no washers on the bolts. I learned from my mistakes years ago, tighten the starter bolts to 35 ft lbs. Make sure you have excellant grounds also.
Old 02-11-2013, 08:49 AM
the starter and flexplate are matching to the transmission the only difference is the engine. a buddy of mine told me to shim it 40 and it fixed it but now the engine wont start (never started after new gaskets) and everyone told me timing. i kinda forgot to install the dist. on compression stroke of #1 cylinder. could it be the dist.
327 Starter mount on block broken off. BestGeneration67 Engine 7 02-05-2012 08:41 AM
327-383 now starter wont fit sooper Engine 5 02-28-2010 05:51 AM
Different 327 starter problems? 1974blackz28 Engine 2 01-06-2010 07:23 PM
327 Starter problem 1974blackz28 Engine 7 01-02-2010 05:04 PM
Starter shifting and grinding.. new starter? Where does starter brace go? 84Z Engine 8 11-12-2007 03:44 PM
