Thread Tools Search this Thread share on Facebook
  #1
Old 02-04-2012, 11:31 AM
BestGeneration67 BestGeneration67 is offline
327 Starter mount on block broken off.
What's going on all. Lots of good knowledge on this site. I know from reading some of the posts I need to get the adapter plate to mount a new starter or get a starter with 3 mounting holes.
Has anyone had sucess with the 3 hole starter and which flywheel do you use with the 3 hole starter? Please provide part # for 3 hole starter.
What is an easy way to be sure what tooth flywheel you have when assembeled / mounted?
Adapter plate users, do you have any info to share on your install and sucess? Thanks!
Steve
Register now (free) or login to remove ads
Old 02-04-2012, 11:44 AM
cobalt327's Avatar
WFO
Wiki Edits: 1,616
If the two bolt holes that are across from each other are still OK, another option is to use a 'mini starter' that uses the bolt holes for the small diameter flex/flywheel for BOTH sizes of 'wheels.
An example is one like: http://www.summitracing.com/search/...orque-Starters/
If the starter that was on the engine had the staggered bolt holes- which it would have had, or you wouldn't have a problem w/the outer staggered bolt hole being broken- you have the 168T flexplate. The starter w/holes across from each other are for the 153T.
You could use a small diameter (153T) flexplate and a stock type starter, as well.
Old 02-04-2012, 12:54 PM
junior stocker's Avatar
junior stocker junior stocker is offline
ALL 3 bolt mounted/bell housing mounted starters use a 168 tooth flywheel/flexplate. The ring adapter plate must use this setup. It's original purpose was so later model automatic transmissions could be used with the 55-57 265's as they did'nt have provision for block mounted starters, nor could they be drilled for one. The adapter ring also works to save a block with a brocken starter pad mount, big or small block. Any 55-62 V-8 starter (except 62 327, Chevy II, some trucks, and maybe the 409) will work. The ring will work with standard and automatic transmissions, not that they were actually designed for that.
Old 02-04-2012, 04:22 PM
Thanks for the info cobalt327 and junior stocker. Hey cobalt or anyone else, does summit have a mini starter that mounts using the two holes closes to the block, on a small block chevy 327. The broken block mount is the outside one, the two inside holes are good. Hey thanks for the quick replies last time. I'll do the same when possible.
Old 02-04-2012, 04:58 PM
vncruiser's Avatar
vncruiser vncruiser is offline
Gearhead
A good machine shop can repair the block. Saw an article in Car Craft about 2 months ago on this very subject
Reid
Old 02-04-2012, 07:29 PM
cobalt327's Avatar
WFO
Wiki Edits: 1,616
My mistake- the mini starter won't work w/what you have going on. Don't know of a starter that uses the inner holes, either.
Old 02-04-2012, 07:53 PM
stich626's Avatar
stich626 stich626 is offline
gearheadslife
Last journal entry: The TwoTonShu #10
last starter bolt mount I fixed was on a 305.. I built up the area with jb weld,
then drilled and tapped the area.. that was 60 some oodd thousand miles ago..
Old 02-05-2012, 07:41 AM
upstand2 upstand2 is offline
Middle starter at the bottom of the page.
http://www.powermastermotorsports.com/chevy__gmc.html
Back to top
Search this Thread:
Advanced Search
vB code is On
Similar Threads for: "327 Starter mount on block broken off."
ThreadThread StarterForumRepliesLast Post
starter adapter for broken block ear sm blkoreilly managerEngine205-10-2011 04:21 PM
350 starter mount bolt hole broken...oldschool70k5Engine203-25-2010 11:55 AM
Broken starter boss on chevy small blockBucks67Engine1409-30-2009 05:48 PM
broken bolt housing on 350 block for the starterbearmacias27Engine807-13-2007 08:55 PM
broken block at startertnsmith10Engine312-28-2005 07:22 AM
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.6.0
