Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 327 timing ??
Thread: 327 timing ??
Old 08-22-2012, 06:21 PM
68NovaSS's Avatar
68NovaSS 68NovaSS is offline
Moderator
Wiki Edits: 9
First things I would check are timing, make sure that #1 is at TDC on the compression stroke, recheck plug wires, and ensure valves aren't too tight. Popping through the carb sounds like 180 degrees out.
Semper Fi
