Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 327 timing ??
Thread: 327 timing ??
Old 08-22-2012, 08:03 PM
cookieman cookieman is offline
I have done all that several times I set hydralic lifters at zero then 3/4 turn someone said 1/4 to 1/2 is better I am familiar with ignition timing not so much valve timing would the valve timing being off have same symtoms as timing being off I have never heard a motor spin with valve timing off ?? also I know just what you mean it acts like it is 180 out butit isn't if I need to I can pull cover and check mark alignment on cam and crank Thanks ,Michael
