Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 327 timing ??
Thread: 327 timing ??
Old 08-24-2012, 12:33 PM
cookieman cookieman is offline
Originally Posted by RWENUTS View Post
Easier and quicker to pop off the distributor cap, point the rotor at #1, loosen distributor, lift it up, rotate rotor over to #6, bolt her back down, cap on and see if it runs.
you say point rotor at # 1 do you mean bring #1 up to tdc then turn dist to # 6
