I had the same problem it was 180deg off. Bring #1 up to tdc then pop your distributor cap off if your rotor is pointing to # 6 than it's 180 deg. off. Take your distruberator off and rotate it 180deg. with the rotor facing the number #1 it should turn on. To advance your timming turn the distributor counterclock wise.
