-   -   327 timing ?? (http://www.hotrodders.com/forum/327-timing-223213.html)
cookieman 08-22-2012 04:37 PM
327 timing ??
Rebuilt 327 points distributer, ballist resister, quad carb,stock manifold, # 1 top dead center, 18436572 clockwise will not start( popping,) back acting like timing off I have replaced points,condensor, double checked top dead center checked getting fire, double checked valve clearnace hydralic lifters any suggestions what else could be ,Thanks ,Michael
68NovaSS 08-22-2012 05:21 PM
First things I would check are timing, make sure that #1 is at TDC on the compression stroke, recheck plug wires, and ensure valves aren't too tight. Popping through the carb sounds like 180 degrees out.
cookieman 08-22-2012 07:03 PM
I have done all that several times I set hydralic lifters at zero then 3/4 turn someone said 1/4 to 1/2 is better I am familiar with ignition timing not so much valve timing would the valve timing being off have same symtoms as timing being off I have never heard a motor spin with valve timing off ?? also I know just what you mean it acts like it is 180 out butit isn't if I need to I can pull cover and check mark alignment on cam and crank Thanks ,Michael
RWENUTS 08-22-2012 08:22 PM
Easier and quicker to pop off the distributor cap, point the rotor at #1, loosen distributor, lift it up, rotate rotor over to #6, bolt her back down, cap on and see if it runs.
cdminter59 08-23-2012 08:02 AM
327 timing ??
When setting the timing you find top dead center by bumping thr engine over until air blow out around your finger. Then take a socket and breaker bar line up mark on 10 BTDC. Pull cap to see where rotor is pointing. Make sure plug wires are correct at this time. Here is a diagram of a Chevy V8 points distributor Google Image Result for http://ww2.justanswer.com/uploads/ASEMaster35yrs/2010-03-17_090540_chevy_v8_firing_order_diagram.jpg It should be close enough to start and set timing.
cookieman 08-24-2012 12:33 PM
you say point rotor at # 1 do you mean bring #1 up to tdc then turn dist to # 6
jxhinoj 08-24-2012 03:22 PM
I had the same problem it was 180deg off. Bring #1 up to tdc then pop your distributor cap off if your rotor is pointing to # 6 than it's 180 deg. off. Take your distruberator off and rotate it 180deg. with the rotor facing the number #1 it should turn on. To advance your timming turn the distributor counterclock wise.
