327 timing - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-13-2003, 09:48 PM
Question 327 timing
hi.i have a 327 eng.with a 600cc holly carb,headers and a stock cam.everthingthing else is stock.does antone know about what the timing should be a idea. around 800 to 1000 rpms? and what rpm should the timing be set at and what should the timing be? thanks to anyone that responds <img src="graemlins/spank.gif" border="0" alt="[spank]" />
Old 02-13-2003, 10:30 PM
DoubleVision's Avatar
Post
12 degree`s BTDC base, and 36 to 38 degree`s in by 3000 RPM`s, if detionation is detected, back off 2 degree`s at a time until it stops and your set.
Old 02-14-2003, 12:08 PM
Thumbs up
thanks
