327 Troubles - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-06-2006, 12:42 PM
sscamaro_510's Avatar
327 Troubles
My Camaro has been acting up,it's been shutting off lately when I give it gas or just during idle. This isnt the first time this problem has happened,it happened before and we messed with the Mixture screws on the carb and it ran fine for awhile...now it's doin it again. It'll accelerate on it's own and then stumble and turn off. Is this a carb problem or does it just need some fine tuning? I also need a new set of headers....which ones do you guys suggest? The carburetor is a 1405 Edelbrock....I been thinking of purchasing another holley carb...if I do go that route which one do you guys suggest I get? Sorry for all the rookie questions....I just want my Camaro back on the road. Also what performance upgrades can I get too make her run a little better? It already has HEI,Edelbrock performer intake and headers. Also,ive been using these cheap Alternator brackets and this is the second time it's broke on me...it's the kind that bolt up too the header bolts...cheap 10 dollar part....do they sell a better system so I dont have too go through this crap of changing out brackets again? lol Damn that's alot of question in one....hopefully someone can help me out....thanks in advance.
Old 12-06-2006, 12:53 PM
Have you looked into a Weiand 177 supercharger? Dollar for dollar, no better performance upgrade than a supercharger.
Old 12-06-2006, 04:43 PM
TailGater's Avatar
Blood, Sweat, and Gears!
kinda sounds like you might have a vacuum leak somewhere, have you checked your vacuum lines to see if one of them might have cracked or come off?
Old 12-07-2006, 09:27 AM
I havent done the Vacuum Check,ill do that when I get home today. Any advice on my other questions?
Old 12-07-2006, 09:34 AM
Alternator brackets: nothing stouter and more troublefree than a stock GM bracket. Yeah, they're not pretty but you can whittle away alot of that iron and make a very servicable piece that doesn't look bad at all and is hell for strong. If you must get it plated, do it, but the cost rises in relation to the shine.
Old 12-13-2006, 09:44 PM
Bump bump...
Old 12-13-2006, 10:06 PM
Check your choke as to your run problems, FLOWTEC headers less than 100 dollars for a small block chevy, you want to go faster spend more money only way, Wormy.
Old 12-16-2006, 05:01 AM
Paul Suburban Murray's Avatar
Blazer Paul
Did you change the power valve in the Holly carb, if they back fire the power valve blows and you get bad idle and stalling, this is why I swiched to edelbrock. Very common problem with Holly carbs.
Paul
DZ 302 Vs 327 ???? oc00l Engine 37 11-18-2008 09:53 AM
Chevrolet 327 TEEMCDEE9552 Engine 15 06-09-2007 08:22 PM
help make my 327 angry!!! 70chevelle327 Engine 41 04-24-2007 05:33 PM
Just got my 327 running timing troubles Mr. Wormy Engine 28 01-31-2006 01:25 PM
65 Impala 327 Troubles EazyDuzIt102 Engine 2 02-25-2004 08:35 PM
