Any non technical comments directed to me? Use the PM.
Not that this thread has any particular technical value anyway, but in the event that it's not locked, I'll expand on my earlier post about the differences in the casting shapes: ![]() SBC 265 CID ![]() SBC 283 CID ![]() SBC 327 CID SJ The 327 had a closer rib than the 283 that you couldn't get a finger into easily. The 265 lacked any rib. |
AP72
I'll not defend the claim that a 2 bolt main has less parasitic loss than a 4 bolt main configuration. Actually I was stating a general opinion, "some prefer a 2 bolt main because they believe it has less parastic loss" would have been more correct. I apologize for misrepresenting as a scientific fact. I tend to agree with you, but I do know some engine builders that prefer the two bolt configuration and claimed this was the reason. When they are winning races with these engines it at least appears they have some credibility. This would make for an interesting experiment, unfortunately it would be (almost?) impossible to build two engines (1 with 2 bolt mains, 1 with 4 bolt mains) that didn't have other inherent differences that would overshadow any measurable performance differences in the two configurations. Assuming the same bearings are used, with same clearances, it would seem that the clamping force of the main bolts would have little or no effect on the parasitic drag. Beside, in the most practical sense, the difference would be negligible. Still, another way to look at it might be: in the glorious search for horsepower, leave no stone unturned. |
I have heard that comment related to 400 CI small blocks. I hadn'd heard it with reference to non-siamesed SBC block castings. Maybe one of the machine shop guys, or other pro builders here could ring in.
I'll give Grumpy Jenkins a call.
He did autograph a 1/24 scale Camaro for me, I think that makes us great pals.Now there is some B.S. for you. There is no reason to get snarky about any subjects, it's just not worth it. It's ok to dis-agree, but let's be civil about and keep things on a non-personal level. If you don't like someone or their answer, rise above playground tactics and have a discussion as to why there is a disagreement. And...read a post a few times before letting yourself get upset over anything in the post. It's tough to comprehend the meaning of the written word, it may sound OK in your mind but comes out like a spew of idiocy ehrn written. Not pointing at ANYONE here but you guys understand what I mean. This isn't the OTHER WEBSITE, let's play nice.
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain |
The reason a 2-bolt 350 block might be the preferred piece over a factory 4-bolt piece, is the ability of a 2-bolt block to be fitted w/4-bolt aftermarket caps w/splayed outer bolts.
With the 400 blocks, it is thought that the loss of material in the critical area where the extra bolts are drilled for the OEM 4-bolt 400 block makes those blocks weaker than a 2-bolt block w/no loss of material in the critical areas. |
I know an IMSA engine builder (800+ HP range and 8-9000 RPM range) and he uses the 400 2 bolt main blocks because he can splay the addition bolts. He wants the added strength gained from the splay vice threads only for the standard 4 bolt. Getting back to the question on how to tell if a SBC is a 327 or a 350, my answer is tear it down then you will know as long as you have your numbers book handy along with your mics. I have seen such mix match of parts in blocks that have casting and stamped numbers of a smaller displacement engine and even seen epoxy and sand used to modify the casting numbers to get an advantage on the local tracks. The old racers adage of "If you ain't cheating, you ain't trying hard enough" brings out all kinds of innovation. One motor I bought from a racer had the casting numbers of a 283, but it was actually a 350 and the heads had the casting numbers and markings of a small valve power pack but they were the large valve power pack heads. He would lead most of the laps handily but always faded on the last couple of laps to finish in the top 5 and not get torn down.
Trees |
back in the day when we had a short track locally they had a device they called "the bubble". Looked a little like a compression gauge setup. They would test the winning cars after every race to check engine displacement.
Something like this would be helpful in these situations. Has anyone else ever seen one of these?
Artificial Intelligence is no match for Natural Stupidity Chet |
I have heard of them. Usually, the money winners get checked: finish out of the money, no check.
I once got a out dated super trick comp eliminator motor. When I removed the pan it had 4 bolt caps on a 2 bolt block running just the 2 bolts. Go figure
