Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 327 wont start
Thread: 327 wont start
Old 07-29-2011, 03:11 PM
madmaxx886 madmaxx886 is offline
327 wont start
so i installed a new intake and carb after getting rid of some holleys. Afterwards my engine would crank but not start. I have a mallory coil and the associated electronic ballast, there is 12.2 volts going into the ballast and 3 coming out. When i crank the engine with a multimeter on the coil it says there is about 1 volt. Im assuming that that isn't enough to spark a plug considering my timing light wont even strobe. Any advice?
Need more information, it this a full Mallory ignition system, coil, distributor and all? What vehicle? Do you need that ballast resistor?
Last edited by 68NovaSS; 07-29-2011 at 03:19 PM. Reason: Violation of guidelines. Please see: general board guidelines.
