Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 327 wont start
Thread: 327 wont start
Old 07-30-2011, 09:07 PM
lg1969's Avatar
lg1969 lg1969 is offline
Google "Tunnel Ram 406"
When you crank the engine there is no voltage coming off the ballast resistor. The voltage is coming from the solenoid and it should go to positive terminal of the coil. It bypasses the ballast resistor. It should read a full 12 volts when you cranking it and about 10 volts when the ignition switch is on the "on" mode. I don't know how you wired yours but this how standard chevy is setup.
