327 wont start - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-29-2011, 03:11 PM
327 wont start
so i installed a new intake and carb after getting rid of some holleys. Afterwards my engine would crank but not start. I have a mallory coil and the associated electronic ballast, there is 12.2 volts going into the ballast and 3 coming out. When i crank the engine with a multimeter on the coil it says there is about 1 volt. Im assuming that that isn't enough to spark a plug considering my timing light wont even strobe. Any advice?
Need more information, it this a full Mallory ignition system, coil, distributor and all? What vehicle? Do you need that ballast resistor?
Last edited by 68NovaSS; 07-29-2011 at 03:19 PM. Reason: Violation of guidelines. Please see: general board guidelines.
Old 07-29-2011, 03:46 PM
Its a t bucket with a 327 and t350. I believe that the distributor is a mallory too (2548201) and as far as that resistor i'm actually not sure if i need it or not it came in the box with the coil, but the engine did start before I did the swap with that resistor in.
Old 07-30-2011, 08:48 PM
dklong's Avatar
is the system points or electronic ign , points you need a balast resistor , electronic you don't need one,
the balast resistor isn't put in out enough voltage, try by-passing it or replacing it
Old 07-30-2011, 09:07 PM
lg1969's Avatar
Google "Tunnel Ram 406"
When you crank the engine there is no voltage coming off the ballast resistor. The voltage is coming from the solenoid and it should go to positive terminal of the coil. It bypasses the ballast resistor. It should read a full 12 volts when you cranking it and about 10 volts when the ignition switch is on the "on" mode. I don't know how you wired yours but this how standard chevy is setup.
Old 07-31-2011, 03:28 AM
so I think I found the problem. I have a dual point distributor and one of the points is pretty worn out. I took the distributor out and with the key on I had full power all the way to the coil output. I have an electric conversion kit on order.
sbc 350 will start run rough for a few seconds die and wont start fuel-junky Engine 11 01-08-2013 11:30 AM
Wont start - bad gas? Torque454 Engine 16 03-02-2010 07:38 AM
305 Wont start SirMikesAlot Hotrodding Basics 4 10-26-2009 01:26 AM
wont start Thumper_Pumper Electrical 13 05-14-2008 03:10 PM
Wont start and need help nomis30 Engine 6 12-25-2003 09:38 AM
