33,34 Ford ratrod pickup plans - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-07-2006, 10:21 AM
I have recently acquired a 33, or 34 Ford truck, I believe it is a AA. It was used as a farm truck, and was parked in a field in 52. All I am going to end up using is the cab. The truck is actually a 1 1/2 ton, so the frame is HUGE. What I am searching for, is if anyone has any measurements for me to start with on a frame, OR even better a set of frame plans.
I want to run a similar stock front end, lowered with the transverse spring.There will be a 429 going up front. And like I said, all I have are the cab, and a bed that I found on another farm. I have abet with my wife that I can do this truck under $7000. I picked the truck up for $400, the bed for $50, and I traded a pistol for the engine. So I think I may make it. Any help would be greatly appreciated.
Thanks!
God Bless Our Troops!
Mike
Old 05-07-2006, 03:57 PM
Nightfire's Avatar
Young & Idealistic
Last journal entry: 1950 Fargo - losing hope
Wiki Edits: 4
Hitting the 7k mark shouldnt be a problem.
www.olskoolrodz.com
www.jalopyjournal.com/forum
www.ruffrodders.com
All the above sites have a swap meet section with cheap parts, and I'm sure they'll be able to provide you with plans for the A frame as well.
Mike
USING LATE 80'S FRAME FOR A 1937 FORD PICKUP DIGGER Body - Exterior 24 08-24-2013 07:25 PM
36 Ford Pickup truck radiator/grill shell assembly Wes Searcy Introduce Yourself 11 10-03-2008 03:08 PM
33 Ford Pickup Shootest Introduce Yourself 2 02-22-2006 10:41 PM
FUEL TANK FOR 1928 Ford A MODEL PICKUP Malcolm W. General Rodding Tech 1 07-21-2005 10:57 PM
40 Ford Pickup Body Parts enemyace Body - Exterior 1 03-23-2003 10:54 PM
