33 chevy ongoing project - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-23-2011, 12:21 PM
planing on turning my 97 vortec 350 into 383, tring to figure out which head to use the stock vortec or a set of Lt1s , the 96 Lts may be more trouble than their worth, anybody have the answer. My 33 chevy is an ongoing project (11 years) but I'll finish it one day soon. I have a comp cam in the 350 (thumper ). want to use 3 deuce set up for the carbs. What do you think. I have a bow tie overdrive 700r4 trans with jag rear 3.73
Old 11-23-2011, 12:31 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Use the Vortec heads. They flow as well if not better than the LT1 head and don't require welding, etc. that the LT head does to make it work on a non-reverse cooled block.
The Vortec will not allow for more than about 0.460" of lift w/o clearance between the seal and retainer being too close and the springs themselves are too weak for most aftermarket cams so they have to be changed.
There are spring packages that can be used to get around having to machine the guide boss for clearance or you can have the boss shortened and cut for seals if you prefer.
There are a lot of threads here and elsewhere on this, CLICK for some more info on Vortec heads and mods to them, etc.
Old 11-23-2011, 01:27 PM
SSedan64's Avatar
X2 on 'Cobalt327' suggestions.
Tuning 3 Deuces with a Thumper Cam should be fun.
These are Pics of my ongoing progress of painting my car. For your enjoyment. Mycophiles Body - Exterior 1 03-24-2010 10:29 PM
Ongoing Cold Start Issues 10mikeymike Engine 9 09-28-2008 04:24 PM
Ongoing warfare Nightrider Off-Topic 43 08-17-2008 02:21 PM
Ongoing problems with my 700r4 tranny Don Zdybel Transmission - Rearend 1 09-02-2007 08:48 AM
ongoing saga of the '82 dodge DR132 Engine 4 01-30-2007 10:53 PM
