33 ford truck frames - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-22-2003, 06:48 AM
New Member
who has 33 ford truck frame rails and are they the same as a 32 or 34? i have seen frames for 32 and 34 but not 33 .thanks for any information
Old 11-22-2003, 09:46 AM
adtkart@aol.com
According to the specifications from Wescotts, 33-34 frames are the same. The pick-up used the same frame with different mount holes.
This info is out of the book, "How to build Hot Rod Chassis" by Tex Smith, page 25.
Old 11-22-2003, 10:50 AM
Frisco's Avatar
Glad To Be Here
If you are looking to purchase the frame check this out.
http://www.hotrodheaven.com/tech/chassis/chassis14.htm
and
http://www.hotrodheaven.com/tech/chassis/chassis15.htm
Great setup!
Old 11-24-2003, 08:39 AM
Bluejackets67's Avatar
Henry Ford didn't waste much. 1932 car "leftover" frames were used on 33 trucks. Once Henry used up the 32 frames, about midway through 1933, he used the 33-34 car frames. Check your wheelbase. This will help you determine if its a early 33 or late 33.
