'33 Ford Tudor Sedan build - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
Hot Rod Forum : Hotrodders Bulletin Board > General Discussion> Projects/Builds/My Ride
  #16 (permalink)
Old 02-27-2013, 01:29 PM
sedanbob's Avatar
Battery box behind the back seat and remote charging terminals mounted under the gas tank cover. Made a fiberglass bracket that hooked over the rear spreader bar - cables go up through the floor next to the battery box. A local exhaust shop ran the pipes. We reduced from the 2 1/2" coming out of the headers to 2 1/4" to make the turns a little easier, then back up to 2 1/2" for the Hushpower mufflers and out the back. Got these grommets from Street Rods by Michael, and made my own brackets to hang the exhaust.
ID:	71833   Click image for larger version
ID:	71834   Click image for larger version
ID:	71835   Click image for larger version
  #17 (permalink)
Old 02-27-2013, 02:07 PM
sedanbob's Avatar
Interior was posted recently, but I'll repeat some of it here. Seat frames and foam came from Wise Guys. We sent them the fabric and they made the covers as well. Rear seat is a front seat from a coupe, which gives me a tilting/reclining back. My battery box is back there, and some room for storage (probably a toolbox).
ID:	71837   Click image for larger version
ID:	71838   Click image for larger version
ID:	71839   Click image for larger version
ID:	71840   Click image for larger version
  #18 (permalink)
Old 02-27-2013, 02:32 PM
sedanbob's Avatar
A couple of tips: Factory steering columns with shifters usually have a neutral start switch built in. These are usually missing on aftermarkte columns. Although they don't advertise it, Ididit will add a neutral start switch to a column for not much money - just tell them how high/low you want it on the column. That switch also includes a terminal for backup lights, should you want them (I did).
Grommets for passing wires through a panel are usually designed for thin sheet metal - when wiring a fiberglass car, often the panel is much thicker and not always even all the way around. A short section of rubber hose glued into the hole makes a good grommet and provides some strain-relief at the same time.
Name:	neutral safety.jpg
ID:	71842   Click image for larger version
  #19 (permalink)
Old 02-27-2013, 07:47 PM
sedanbob's Avatar
Another couple pieces - I added a 3rd brake light. I molded a bump on the rear window garnish molding to hold a strip LED. It shows at the bottom of the read window, but doesn't show when it isn't lit because of the tinted glass. The gas tank cover I had was intended to mount a rear bumper, but I didn't want bumpers, so I mounted oval back-up lights on the 'frog eyes' where the bumper would have mounted. I used side marker repeater lights off a Ford Explorer, swapping the yellow bulbs for clear.
ID:	71848   Click image for larger version
  #20 (permalink)
Old 03-01-2013, 10:19 AM
sedanbob's Avatar
Some of the earlier pictures were too large and wouldn't upload. Here is the chassis/body loaded on the trailer coming home from Redneck at the beginning of the build, a shot of the interior panels they offer, and a shot of the grille from Alumicraft.
ID:	71888   Click image for larger version
ID:	71889   Click image for larger version
ID:	71890   Click image for larger version
Name:	2012-10-06 12.08.20.jpg
  #21 (permalink)
Old 03-01-2013, 10:29 AM
sedanbob's Avatar
I borrowed a set of wheels from my son-in-law that were 5 on 4.5" bolt pattern, but forgot about the backspacing. The fronts we had to stack washers on the lugs to space them out so they wouldn't rub, but we couldn't get the back wheels anywhere close. The wheels were from his Mustang and had way to much backspacing to fit. I borrowed the back set from Redneck for the trip home.
  #22 (permalink)
Old 03-23-2013, 08:17 PM
sedanbob's Avatar
Latest shot of the dash.
  #23 (permalink)
Old 03-26-2013, 09:54 PM
Wow! That is amazzzzing
Steller workmanship and I am so diggin that color.
Janice
The Following User Says Thank You to janie's dirty 37 For This Useful Post:
sedanbob (03-27-2013)
  #24 (permalink)
Old 03-27-2013, 01:02 PM
sedanbob's Avatar
Thanks Janie - kind words. Took a little over 4 1/2 years. Color is from a Toyota Highlander (around '06) - Sonora gold pearl.
47 Ford Tudor Sedan Owner brepei Introduce Yourself 3 01-27-2012 11:10 AM
48 ford tudor sedan bgraham Suspension - Brakes - Steering 4 09-05-2011 07:26 AM
41 ford tudor sedan Old Farts General Rodding Tech 6 11-27-2006 08:19 AM
41 ford tudor sedan Old Farts Interior 3 11-05-2006 09:01 AM
1934 Ford tudor sedan Silver00V6 Hotrodding Basics 1 08-02-2004 12:22 PM
