33 Ford windshield fit up issues - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-24-2012, 09:01 AM
Merry Christmas
I have a 33 Ford that I chopped the top on a few yrs ago. I just recently cut the stock windshield frame & installed the rubber seal around it to check fit up. The windshield will not close w/o applying pressure, & even then there is a good 1/2 inch gap between the base of the windshield frame & the dash mounting lip. I checked the fit up w/o the rubber seal, & it is better - so I'm thinking the rubber seal is not correct, even though it is from a reputable supplier.
Anyone face this problem before ? What rubber windshield seal do you find fits the best ? Also, just to check my dimensions, does anyone have dimensions of a stock windshield frame opening on the car (in the middle would be OK) .
Thanks,
Mike.
38 ford windshield 38harry Body - Exterior 3 01-08-2009 08:35 AM
36 Ford P/U Crank out Windshield yeatman Body - Exterior 1 05-26-2007 02:16 PM
53 ford windshield PaulNJ53Ford Body - Exterior 4 02-14-2007 08:01 AM
'40 Ford Windshield suede71 Body - Exterior 2 08-10-2003 01:29 PM
Windshield Frame doesn't fit - help 30 sportcoupe Body - Exterior 4 01-05-2003 02:41 AM
