3300 pound car; want to do 12's in 1/4 mile - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 04-08-2013, 11:12 PM
Title weight says 3309 pounds. 2 hundred pound driver. So l'd say at most 3600 pounds more than likely less weight due to stuff taken off the car, keeps it lighter. Super charging 305 can't be done. The engine needs help losing a main bearing or oil pump low pressure. Rather build a 350; got a friend that does dirt track. Put's 305 HO heads on 350s between 10-10.5 pressure ratio Flat tops. Seeing what l could do with that kind of set up
  #17 (permalink)
Old 04-08-2013, 11:56 PM
I can not do that. Way too much for cash wise lol
  #18 (permalink)
Old 04-09-2013, 12:55 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Don't trust title weight. Title weight on my '09 Silverado is 5800, true certified CAT scale weight with me in it at 180 pounds is 7140. The only addition from the factory is a 40 gallon aux fuel tank, about 350 pounds full, so my actual weight is almost 1,000 pounds more than stated.
Semper Fi
  #19 (permalink)
Old 04-09-2013, 06:14 AM
vinniekq2's Avatar
350 with,cam like this hydraulic roller
110255-10 CL110255-10 284 288 231 235 .510 .530 110 106 Hyd. Hyd. 1,2
2200-5800 Rough idle, Street/Strip performance. Great low to mid-range torque & power.
750 hp Holley,performer air gap, Dart shp or better heads,10:1 cr,1 5/8 long tube headers,MSD 6AL or better ignition,3k-3300 converter,50/50 rear shocks,maybe 90/10 front shocks???loosen sway bar on front when racing,improved fuel delivery system,28x9 slicks or maybe shorter?lose 100 pounds off front of car,more total if possible.
If you buy bargain parts,think about a little more cam&CR&rear gear.
  #20 (permalink)
Old 04-09-2013, 06:36 AM
Banned
Originally Posted by spinn View Post
750+ carb
hi ignition
good single plane for 6500 rpm+
mechanical cam like 284/284 .530+" compression to match
deep pan increase capacity
manual body
4000 stall
4.30+ gearing 9+ x 28" slick
Go all out.
I never made it past 13.0 flat. If I wanted to crack into the 12's with a sbc , I d try that.
my 1982 f body at 3400 lbs
355 10.5 to 1
292 flat tap hyd
dual plane intake
q jet
th400 3200-3500 stall , no manual v/b
4:11 gears and 28" slicks.. ran 12.78 on motor
and almost 10 flat on gas
cars set up. is worth more that hp.. 9 times out of 10
  #21 (permalink)
Old 04-09-2013, 07:47 AM
Faith - Respect - Trust
"Gearheadslife' I think your right in many cases about the cost of suspension set up being worth more than horsepower. I've had some real torque monsters of motors that ran high ET's, put the proper suspension underneath that engine and cut a lot of that quarter mile time...it's all about how to get the most use out of that strong engine. Loosing weight, the right tires, gearing, suspension, they all play rolls every bit as important as Horse Power. One question I've never hear'd an OP ask is, how can I improve my driving skills to get a better ET. The difference between me driving my 70 AMX in quarter mile and my wife driving the car is about 10 seconds, why, same car, same Horse Power and in this game 1/100 of a second can be the difference between winning and loosing.
Ray.
350 will not rev on 3300 rpms HOTRODtwan80s Engine 9 03-16-2011 06:14 PM
383 chevy for 11.9 1/4 mile 3350lb car help belairheaven Engine 25 02-10-2010 08:49 PM
RWHP and 1/4 mile estimate on new car firestone Engine 12 04-13-2007 07:19 AM
make my car quicker in the 1/4 mile Quddus Hotrodding Basics 14 02-19-2005 05:55 AM
Power Per Pound stereodud Engine 3 10-31-2002 01:50 PM
