331 hemi with extended bell housing - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-18-2002, 07:02 PM
Post 331 hemi with extended bell housing
I have a 331 early hemi with an extended bell house and I found an adapter for a t-10 for it.Does any one know the clutch ,throw-out bearing and fork combination and flywheel for this? I am using a t-5 instead of a t-10 as I need over-drive.
Old 08-19-2002, 06:11 PM
The Vandal's Avatar
Engine Tech Addict
Post
PowerPlayHemi.com is the place to look for this kind of info. I'd love to have an old hemi but an extended bellhousing.............ugly! What's it going into? Have fun!
The Vandal
Old 08-20-2002, 06:06 AM
WoodsEdge's Avatar
Post
Check with Willys36 on this. He's the Hemi expert. If he doesn't see this post, post one to him.
Old 08-20-2002, 06:42 AM
Wiki Edits: 49
Lightbulb
Talk to Bob at PowerPlayHemi.com. He sells adaptors for the 51-53 extended block hemi to Chevy manual trans and has all the parts and expert advice you'll need.
Bill
<a href="http://www.HotRodsAndHemis.com" target="_blank">http://www.HotRodsAndHemis.com</A>
[ August 20, 2002: Message edited by: Centerline ]</p>
Old 08-20-2002, 09:41 AM
willys36@aol.com's Avatar
Wiki Edits: 21
Post
I do run a long bellhousing 331 and have become a sort of expert on it over the past 30 years but I know nothing about adapting manual transmissions to it. I have an old Drag Machine aluminum adaptor for my B&M hydro that I got for a high school graduation present in '67 but that is my only experience with 331 adaptors.
Old 08-22-2002, 06:08 AM
Wiki Edits: 21
Post
There are thwo of these 331 engines on eBay right now! Both are complete, stock, one with auto trans, one with manual trans bellhousing & clutch.
