331 hemi motor mount position - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-23-2011, 04:50 PM
I'm needing the correct spacing from the radiator to center of motor mount on a 331 hemi for my 31 ford, I'll be using an electric fan and sbc water pump,, it's gonna be a tight fit so I'm wanting all the help I can get,,,I'm waiting and held up for parts but would like to get this thing in the frame,,,thanks again
Old 11-23-2011, 07:15 PM
Wiki Edits: 49
The 331 in my deuce is a '55. I'm running a Summit BBC water pump and mechanical fan with a 2" spacer. My engine mounts are exactly 12" behind the back side of the radiator and I still have a little more than an inch between the fan and the radiator.
Hope this helps.
Centerline
HotRodsAndHemis.com
“If money is what makes cars fast, mine otta be going 400 miles an hour!". - Felix Sabates
How much clearance should there be between motor mount and motor mount bolt? firstgear Hotrodding Basics 8 03-21-2013 09:10 PM
motor mount ?? prs General Rodding Tech 4 10-09-2007 04:41 PM
Do SBC and BBC mount in the same position? 70bird Engine 3 11-06-2004 07:16 PM
Motor Mount ID Thom Laybourne Engine 3 09-17-2004 05:25 PM
motor mount Totter Engine 3 05-29-2003 02:42 AM
