I ran your combo on Desktop Dyno using the Edl.RPM flow #'s and XE262 specs. (I ran the cam specs at seat to seat timing. Comp lists the specs @ .006, but Desktop Dyno only uses @.050 or seat to seat)
Torque @ 2000 rpm is 325 ft.lbs., climbs to 360 ft.lbs. @3500 rpm and stays above 300 ft. lbs. until 5500 rpm when it drops to 295 ft. lbs. HP peak is 310 HP @ 5000 rpm. The curve is pretty flat between 4500 rpm and 6000 rpm (around 300 HP). Looks good for your intended purpose. (edit--these figures are for stock manifolds with mufflers. With small tube headers and mufflers peak #'s are: 349 HP @ 5500 rpm & 385 ft. lbs. @ 4000 rpm) Last edited by jhs914; 07-23-2006 at 09:23 PM. |
Just for grins I ran your combo with the XE268H cam instead of the 262.
Peaks are 323 HP @ 5500 rpm and 352 ft. lbs. @ 3500 rpm. Power stays over 300 HP between 4500-6500 rpm and torque is flat between 3000-4500 rpm @ around 350 ft. lbs. (edit- the corrected figures with headers/mufflers are 364 HP @ 5500 rpm & 381 ft. lbs. @ 4500 rpm) Last edited by jhs914; 07-23-2006 at 09:28 PM. |
Performance trends show up at 365hp at 5700, and 400 ft.lbs at 4200. This was using and 1 5/8" open header.
We about a year ago built a 327 for a customer with a set of bowl blended 461's, 10-1, Comps XE274H-10, and a light worked Torker intake (the old style one) and a Quick Fuel 750. I dont remember the torque, but it did make 385hp at 5900. |
I have very similar combo as follows. It was dynoed (rear wheel), 4-speed Muncie, 3.36 rear end, 28in. tires and came in at 290 hp @ 5800 rpm and 320 ft lb torque @ 3900 and was very flat across-ed a wide range
327 ci SBC bored 0.040 over, balanced Edelbrock RPM Alum. heads 2.02/1.60, 64cc chambers KB156 pistons, 7cc valve reliefs Performer RPM intake, Carter AFB 600 cfm carb. CompCams XE262-10, 218/224, 110 lobe sep., .462/.469 lift CompCams roller rockers 1.52:1 Block decked to 0.010, Head gasket 0.028 9.6:1 SCR, 8.1:1 DCR Hope this helps. |
| Pontiac Fiero Owner swapping in a 350, maybe 383 sbc with a v8 archie kit | Fiero Performance | Engine | 2 | 02-24-2009 04:30 AM |
| what stereo wires under carpet? | bullheimer | Electrical | 19 | 05-06-2005 06:37 PM |
| Bad advice | lluciano77 | Engine | 28 | 03-09-2005 06:33 AM |
| Share Your SBC Power Combos!!! | 68firechicken | Engine | 6 | 11-14-2003 03:13 PM |
| 400 SBC Balancing and info ? | Brobob | Engine | 8 | 10-31-2002 03:44 PM |
