3310-3 jets /shooters /etc - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-01-2013, 05:45 PM
Banned
Hello ..
so I will be rebuilding my 750v/s carb to use on my 350 crate engine..
it's a 350vortec crate with the g.m. ramjet rooler cam and 1.6 rockers
it's a 9.4 to 1 with
cam The duration at lash point in degrees (intake/exhaust) is 288/308; duration at .050" tappet lift (intake/exhaust) is 196/206 and maximum lift with 1.5:1 rocker ratio (intake/exhaust) is 431/451. Valve lash is zero/zero and lobe centerline is 109 degrees.
the lift will be e.460 I .481
Now I'm a q-jet guy and will be try'n that out also as the edle rpm intake
is drilled for both..
but I have no idea where to start with jetting and such on the holley..
both ends have metering blocks..
the rest of the vehicle is
3900lb
3.08 gears 26" tire with as of now a th350 with stock(guessing) stall and will move to a 2004r with 2400 stall
I know only an a/f gauge and /or track testing will get me on the money.. but I'd like to be somewhat close to start..
thanks..
the q-jets will be a 74 chevy truck 350 and a 73 pontaic 455 j-jet
timing I'm going to start with the ramjet specs.. and go from there Ignition Timing: Base 10 degrees BTDC, 32 degrees total
Holley 3310-4 logan1 Engine 10 01-05-2012 07:51 PM
holley 3310-3 s-10 carl Engine 2 04-05-2011 02:04 PM
1850 to a 3310!! gofastz Engine 5 06-04-2010 01:29 AM
Edelbrock750 jets vs 600 carb jets KeithB123 Engine 1 01-11-2007 06:02 PM
High Altitude Q-Jets vs std Q-Jets DHMag Engine 3 01-09-2006 06:16 PM
