334 stroker or not?
I profess to know very little about engine building. With that out of the way, the engine going into my 84 GP, which is going to be a cruiser, not a racer. It has the following:
305 block from Z28 Swirl port heads from a 93 pickup 9/16 crank bored 40 over (not sure if that is the correct terminology) Lunati barebones cam and lifters dish pistons flowtech headers Any problems with this? Also what kind of power will it generate? (stock rear end and tranny by the way) |
Need much more information for a power guestimate. What heads, chamber volume, what piston dish volume in cc's, what cam specs, lift, duration, what intake manifold, carb, what exhaust, style, size, what ignition?
9/16's crank?
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. Midnight Sun Street Rod Association |
BTW, a 334 is a 3-3/4" crank in a 305 (0.030" over, I believe). The idea of stroking a 305 is not a particularly good plan, when 4" bore hydraulic roller capable blocks/short blocks/Vortec L31 long blocks are so easily and cheaply available. If it was me, I'd take the guts out of the 305, get a different set of pistons and install it all back in a 4" bore block. If you want to reuse the cam (keep the lifters on the same lobes they were on in the 305), you can use any block (327 or 350, except the Gen 2 LT1/4 engines) but I'd recommend a hydraulic roller block so if in the future you wanted to upgrade to a roller, you could do so easily. The stock differential is weak, you will need to upgrade if you make any real power and have traction. You might want to read up on the subject. |
I do know there are 9/16 cranks, did a search on here to learn all about them.
Using "9/16" is an antiquated way of describing a stroker crank size. I know the term is still in use, but if you want to talk stroker cranks- especially SBC stroker cranks (and not early Hemi or flathead Ford, etc.)- you might want to use the more common decimal/fractional measurements, i.e. 3.48" stroke is stock 350/305/267 crank size, 3.75 (or 3-3/4" if you prefer) is the stroke of a 400 SBC and is by FAR the most common size stroker crank to use in a 4" bore SBC block (327/350), but you'll be hard pressed to find anyone using "3/4 stroker" when describing it. Unless you're trying to fit into an oddball class displacement rule or trying to cheat, there's little point in not using as much stroke as can be used w/o needing to jump through too many hoops (like is required to use a 4" stroke in a SBC, for instance). That means a 3.75" stroke. Which is (as I've already said) what's needed to get 334 cid out of a 305 block. The same crank w/different pistons will get you 383 cid from a 4.030" bore SBC. |
I guess you failed reading and comprehension in school. Read the first line of the post .
Horsepower is how fast you hit the wall. Torque is how far you take the wall with you. Midnight Sun Street Rod Association Last edited by 68NovaSS; 05-01-2012 at 04:22 PM. |
A 10cc dish with proper (.040) quench, .030 overbore, 3.75 stroke and a 5.7 in rod yields 9.2:1 static compression with 64cc heads.
| 383 stroker or 396 stroker crate engine | augustine | Hotrodding Basics | 5 | 11-26-2011 11:12 AM |
| please help with my stroker | shalashaska91 | Engine | 9 | 11-07-2007 08:54 PM |
| 93 Mustang EEC-IV Code 334 | door64 | Engine | 1 | 12-16-2006 08:32 PM |
| supercharged 334 stroker | transam-man305 | Engine | 21 | 11-30-2004 05:18 PM |
| 305 stroker or 350 stroker | cragars | Engine | 3 | 02-11-2004 01:05 PM |
