336781 Heads With Flat Top Pistons - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 07-14-2013, 12:59 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
I bought the heads for $300 / pr. It looks like there are fairly new stainless valves installed along with dual springs. I had looked up some reman ATK heads, and they charge $150.00 core deposit... So worst case scenario is that I have just bought some cores to trade in.
  #17 (permalink)
Old 07-15-2013, 04:29 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by BOBCRMAN@aol.com View Post
I read all three of the above sources. LOTS of incorrect information on them..
Example. 049 heads are also listed as 113cc. They are in actuality 120-122..
Another example. Stated in article that tall deck 427 trucks had 7/16" rod bolts. Completely false!
Plus many more. In this case don't believe what is printed..
Yes, I have actually cc'd many BBC heads and they are usually larger than GM stated spec.. I usually start with a .005" cut before measuring the chambers. A sloppy repair valve job can add cc's of volume to the chamber. Sink that valve/seat and add combustion chamber volume..
Sometimes the low-ball volumes are NHRA minimums- NOT what you see on an undecked head.
In any event, the published figures are ball park. ALL heads (both sides) have to be CC'd in order to know exactly what you have.
compressio ratio .040 w/ vortec heads and flat top pistons streetbruiser Engine 17 12-17-2011 09:59 AM
big block mopar, zero deck, flat top pistons, & open chamber heads? 406 ss monte Engine 9 02-01-2010 01:47 PM
Bbc Heads 336781 Fastest65 Engine 1 02-14-2008 11:02 AM
Flat top pistons Silentlion_69 Engine 13 03-25-2005 07:26 AM
what heads or these GM9T-336781 pass phresh420 Engine 1 11-06-2004 06:06 AM
