336781 Heads With Flat Top Pistons
Have A 454 With Flat Top Pistons ,SLR Cam. Lift Is 532-522 Duration Is 282-292,with Roller Rockers . Had Some Head Trouble, They Were 702's Now Have 336781 Open Chamber Heads . 206-172 Valves Will This Combination Work Just As Well ? Thanks....................gus
flat tops and 781s make a pretty low CR
i dont know what cc the old heads were have the 781s and/or the block been cut/milled ? but it will probably work ok with that cam *I am no expert there are a few guys on here that know more than me maybe they will chime in |
The 702's Are 98 Cc . The 781 Are Supposed To Be 113 Cc. The Block Has'nt Been Decked ,but The Heads I'm Not Sure About As They Are Still At The Head Shop &the Bore Is Still Stock. Thanks For The Comeback...........gus
I dont know what the deck height or the volume of piston or head gasket thickness is gonna be but the flatops with those heads will make that big block sick (wont go!) compresiion,Ithink ,will be in the 8:1 range at best...
Try to get some closed chamber heads or change pistons. |
How much can I mill the 781s down .They have 219 188 valves now .I want to try them on a 454 with a comp extreme marine cam - lift-544-547 duration 226-236 & flat top pistons. stock bore & deck. .......
If you want to use the big valve good 781 ovales it will be well worth it to do it right and get the right dome piston
for this combo. The right pistons are not that much money. A KB hyper or speed pro hyper or probe will get it done. You want a 18 to 26cc dome depending on the desired cr, actual measured head volume and assembled piston to head clearance @ TDC. (deck height) Piston dome to chamber wall clearance must be checked. minor chamber wall clearanceing grinding may be required. This is a really good combo when done right. |
| compressio ratio .040 w/ vortec heads and flat top pistons | streetbruiser | Engine | 17 | 12-17-2011 09:59 AM |
| big block mopar, zero deck, flat top pistons, & open chamber heads? | 406 ss monte | Engine | 9 | 02-01-2010 01:47 PM |
| Bbc Heads 336781 | Fastest65 | Engine | 1 | 02-14-2008 11:02 AM |
| Flat top pistons | Silentlion_69 | Engine | 13 | 03-25-2005 07:26 AM |
| what heads or these GM9T-336781 pass | phresh420 | Engine | 1 | 11-06-2004 06:06 AM |
