33o hemi cam - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-06-2009, 05:48 PM
33o hemi cam
I'm putting a 56 DeSoto 330 hemi together for my 54 Chevy, I was told by HotHeads that the only way to get a cam for what I want is to grind the one I have. I was told by the shop doing the machine work to go to Erson Cams. What I'd like to know is are they still doing business or does anybody make a cam for what I want? Racer Brown will cut the cam.
Old 11-06-2009, 07:16 PM
Wiki Edits: 49
I'm sure you can find a cam maker out there to grind you a custom as I understand some DeSoto blanks are available (but I don't know where). The most cost effective way to go is to have Bob Walker at HotHeads regrind your stock cam. You'll have to use adjustable push rods but you would have to do that anyway since there were no DeSoto hemis I'm aware of (possibly some of the dual quad 345's) that had adjustable rockers.
If you're building a cruiser and not a race engine then a reground cam should work just fine.
Old 11-07-2009, 10:13 AM
330 hemi
Yep, building a cruiser, airride, chopped, etc. You're right, Hotheads seems the place to go for this. I was really wondering about a reground cam, but like you say, as long as it's not a radical grind I should be okay. One thing I've found out,I've done Chevy's all my life, I could do 3-4 of them for the cost of a hemi...
Old 11-07-2009, 06:27 PM
345 desoto's Avatar
Location: Skaneateles, NY Summer/Port St.Lucie, FL Winter
Call Donny Johansson...he will grind you a NEW cam. They have every Master for every cam the ever ground. I scored an NOS roller cam for my 291 DeSoto and sent it to him to spec out for me. He identified it as one of theirs from the late 50's. He said they have the blanks to grind the old DeSoto cams...use your Stock pushrods. You could also call Chris Neilson and see if he got his new repro cams off the ground yet...
Chet Herbert
Street: 15600 El Prado Rd
Chino, ca 91710-7623
Phone: (909) 597-2310
Old 11-07-2009, 10:06 PM
Wiki Edits: 49
Originally Posted by 345 desoto
Call Donny Johansson...he will grind you a NEW cam. They have every Master for every cam the ever ground. I scored an NOS roller cam for my 291 DeSoto and sent it to him to spec out for me. He identified it as one of theirs from the late 50's. He said they have the blanks to grind the old DeSoto cams...use your Stock pushrods............
Depending on the cost of the cam this certainly could be less expensive than going the "reground" route. Considering the cost of adjustable pushrods.
Old 11-08-2009, 09:30 AM
330 hemi
Thanks a bunch, it's not going to be more than a 10:1 motor and trying to get about 300 horse motor out of it. Considering only 10 headbolts I think thats' all the compression cam I want to try because I will be driving it. So maybe that kind of cam will overcome the pushrod cost...hopefully.
Anybody dealt with this guy on ebay? Or through Dirttrackthunder.com? killerformula Hotrodders' Lounge 20 08-31-2008 06:12 PM
I need cam help 355s10 Engine 5 03-16-2008 06:34 PM
early hemi cuda project! need help shipping engines and building an early hemi thecountmc Hotrodders' Lounge 13 12-03-2007 06:21 PM
What cam specs work well with centrifugal Superchargers? hotrodf1 Engine 1 09-22-2007 05:21 PM
305 cam carb manifold stickshift Engine 6 04-12-2005 04:46 PM
