Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 34 Alum. Grill
Thread: 34 Alum. Grill
Old 10-08-2012, 07:51 PM
Jmccrack's Avatar
Jmccrack Jmccrack is offline
Last journal entry: Inner Fender problems
Thanks for the help guys. On a 34 ford the center hinge is 33" long and a Rootlieb hood is made to fit this dimension. When the grill frame is bolted to the top of the rad as it is on a 34 Ford with a 4 piece hood the grill and grill shell is now a fixed distance distance from the front on the rad. In my case the top corners of the rad hit the inside of the grill shell insert. All I need is another 1/16". I think I have solved the problem. I was able to trim a bit off the rad frame on both sides.
