Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - 34 Alum. Grill
Thread: 34 Alum. Grill
Old 10-09-2012, 02:22 PM
FASTFORD's Avatar
FASTFORD FASTFORD is offline
Originally Posted by Jmccrack View Post
Thanks for the help guys. On a 34 ford the center hinge is 33" long and a Rootlieb hood is made to fit this dimension. When the grill frame is bolted to the top of the rad as it is on a 34 Ford with a 4 piece hood the grill and grill shell is now a fixed distance distance from the front on the rad. In my case the top corners of the rad hit the inside of the grill shell insert. All I need is another 1/16". I think I have solved the problem. I was able to trim a bit off the rad frame on both sides.
your information is correct but I immediately thought, elongate the holes for mounting the grille shell to radiator to gain the needed clearance.
would this help...yes,no,maybe ?
